Jim.
I've operated quite a few D9G to D9N tractors and have yet to experience major problems with bevel casings and ripper mounts.
I also recall a newish D10N that cracked the casing.
You won't find an old 9G/H without a few drops of oil around the back end.Some may have been cracked in their younger days and welded back up.
This doesn't mean they won't do your job.
As for fuel burn on the D9..........well,it moves a lot for what it drinks,therefore may only be needed for a few hours a day.
My preference for your job would be an old D8H/K with a nice,simple Kelly ripper.
Get a decent 40 odd ton excavator with a ripper attachment and you have the best of both worlds.
Stick to Cat and you will recoup your investment when you sell up.
Hello Nicky:
I found a D8H that has a bad head gasquet. A few questions. Engines don't normally blow a head gasquet unless they are over-heated, the head is warped or both. Correct assessment? I ask because I see a lot of Cats advertised on Machinery Trader with blown head gasquets. I'm searching now for a mechanic to give me a repair quote. I know on a car engine, when a head gets warped, you either replace it with a new head or you mill down the head slightly to take out the warp. With a high-compression diesel engine, I don't think that milling is an option. So first step is to find out what size Cat engine is in the D8H and buy a new Cat head replacement.
Second question. I know that when ripping, it is critical to have control of the ripper tooth angle. A D8H has a parallelogram-style ripper that only offers a fixed-ripping position. So I had a thought. Maybe a stupid thought. The upper control bars are fixed to the rear of the Cat and fixed to the top of the ripper. Why wouldn't a person take off those upper steel bars and replace them with hydraulic cylinders? All the pressure would always be a compressive force against the tractor. There would be no tension trying to pull away from the tractor. Yes, you would have a control issue but it seems that could be somewhat easily solved with a straight charge/discharge valve, a valve control lever and hoses that would adjust the tooth angle. What seems the most difficult would be finding an appropriate place to tie into the hydraulic system. Also would be an issue is that of the hydraulic pump - if it were strong enough to allow for the addition of the extra hydraulics. Maybe this is a really stupid idea but it sure seems more reasonable than buying a new Kelly Ripper. The Cat can be purchased for the right price, it is nearby and that would be the reason for the extra effort of fixing the engine and making it work.
As for your advice about the excavator/Cat combination, I have come around to believing that would be the perfect combo. By checking the mechanical condition and buying the older equipment, it would reduce the total acquisition cost.
I've operated a back hoe, 4-1 buckets, wheeled and tracked front-end loaders, the largest New Holland skid-steer and two older Cats with frictions and a pony starter motor. That is my dirt-moving experience. I have never operated an excavator. Clearly, I will soon be learning. So now comes a troubling decision. It seems that I will operate the excavator more than the Cat. The tractor will move around the over-burden. The excavator will ("delicately") pick apart the quartz veins and the surrounding wall rock. I found a Cat 345BL that weighs a hundred-thousand pounds and burns dang-near 15 gallons per hour according to the CAT specs. Ouch! Certainly, a 345BL is large enough to dig and has sufficient bucket break-out force from what I've read. But #@%+)%@! 15 gallons an hour? Even with red, off-road diesel that's over $175 USD in a 5-hour day. Scheesh! Maybe that's just the cost of mining, aye?
I know that smaller excavators burn far less fuel - but is a small excavator really up to the task of mining? It also seems that a 345BL is not a machine that one associates with the word "delicate" or surgical with a 5-foot rock bucket! On the other hand, I know that one can pick-apart almost anything with a backhoe in a delicate manner and so perhaps one can do the same thing with a large excavator. I don't know because I've never operated one. Let's not forget, I'm not loading out eight cycling Haul Paks out of a pit in a 12-hour shift so I shouldn't have to run the excavator at full RPM. Maybe that saves a bit of fuel? The bigger machine would be welcome in those cases when the big breakout force is required.
Your advice to stick with Caterpillar products is a good one. I totally agree. One reason people hate big excavators and larger Cats is the hefty transportation cost. In all cases, once this equipment is on site, we won't be transporting it ever again . . . . . I hope. Your comments or any others who know excavators and the D8H Cat would be appreciated.
Kindest Regards,
Jim Mitchell
DLOG FINDERS
