I might be chasing a ghost but I can't take a chance and destroy another engine. I have over $11,000 invested in the machine already not counting my own labor. I am going to take every precaution necessary to get this machine up and running! Thanks for the post...
Steve, I'm not suggesting in any way, shape, or form that you do anything that would damage the engine. No one here is suggesting that. I was just, for your sake, trying to get a realistic estimate of how many seconds the engine ran without oil pressure on the gauge and shed a bit of light on why folks were suggesting circulating the oil using any one of a half-dozen different methods. Reading into the posts, it seems to me that the consensus is that you
probably didn't harm the engine (at least not much) and that there might not be anything wrong. If you pre-circulate the oil as has been suggested (choose what seems like the simplest method) until something (anything!) shows on the gauge (the needle twitches), then crank the engine without compression (pull the injectors if necessary), you should build pressure without harming the engine. If it does, then start it up. If it doesn't, THEN you chase problems. Right now, you don't really know if you have a problem or not.
I'm on your side in this--not that there is a side, we're all anxious for a video of the thing running!--I'm a barnyard, backyard, when-I-have-the-time tinkerer when it comes to yellow iron. But I listen very carefully to what is said on HEF--especially to folks like Nige, tctractors, thepumpguysc, dmiller, junkyard, and I can't name everyone (sorry fellas). Steve, go to the track loader forum (
https://www.heavyequipmentforums.com/forums/track-loaders.52/ ) and sort by "replies" (click on the "replies" column). Read the first two threads beginning to end (Nitelite's and boone's).
I haven't rebuilt a big diesel engine such as what you've been going through--but I do have similar experience with other projects that had tens of thousands of $ on the line with the flip of a switch, so I know that feeling. It isn't fun at that point--for anyone! But it should be reassuring that you have a LOT of people reading your thread and hoping that it all turns out well. I probably wouldn't have bought my 955K without knowing this resource was available.
