This is an old thread, but Cat is working on the problem now.
D6R III wrg00413
8500 hrs
Again, the problem is the c9 acert doesn't like to run when cold. That is to say, it cranks and fires no problem, but after about 15 secs something kicks out, revs drop off, itll slowly idle around 200 rpm for a another say 15 secs, and slowly flutter out. Crank it again and it fires right up, then does the same thing all over again. Depending on the temp(today its about freezing) it can take many start cycles to finally get going and keep running (today it took 3)
This tractor has been like this for as long as I have owned it (2000 hrs)
Injector cutout test shows all is good.
Tech with gauges and laptop plugged in confirm fuel and injector activation pressures are bang on. The fuel boost pump at the filters is new so that isn't an issue. Filters new.
He noticed the fuel pressure sensor was reading 259psi when the engine was off. Not terrible, but changed it anyway. Also, for lack of another idea, he changed the fuel rail pressure regulator. Again, cheap enough no sense wondering if its good.
After this the problem persisted, so he has run back to the shop as I type this to grab a engine speed sensor(camshaft sensor)
He says the engine is calling for 800 rpm and getting about 500. No codes. past experience says the speed sensor can cause odd behavior. Grasping at straws here.
The only other thing I can add is the smoke during warmup is on the black side. not a lot, but not white.
