rsherril
- Joined
- May 2, 2009
- Messages
- 264
- Location
- Far West Colorado
- Occupation
- Geologist, Retired from teaching sciences
Went to do a little road work today. Checking fluid levels and engine oil too high. No diesel smell, coolant low, drain about two gallons of coolant out of oil sump. Sure glad I always do fluid checks first thing.
Backround: Parked one month ago after plowing snow for 5 hours. Had to replace block heater first. Added coolant. Did notice a chirping noise towards the end of day. Nothing apparent when I looked around. Noted engine running a little warmer, not hot.
Did note on today's oil check that that oil was black, not the usual dark brown at 200 hrs.into last oil change.
Coolant was flushed and changed to Final Charge about 150 hours ago.
Engine is a JD 6059 with a turbo with 2900 hrs. Repowered in 1992. Radiator recored in 2004 at 1650 hrs.
Total coolant capacity 5.6 gals.
Would guess that coolant pump is in need of replacement. Gaskets, seals and impeller. Concerned about turbo bearings and other things I don't know about as well as things I think I know about. Not much of a wrench man, but am 8 years into this old grader and need advice so I can keep going awhile longer. Thanks ahead,
