I did a little testing on my 730A today. There was 11.99 volts at the articulation switch which is good. I didn't get volts when pushing the switch but I think I was checking on the wrong terminal. Online it looks like the wire terminal on the opposite side you push the toggle switch is the one to check. There is definitely a solenoid missing on the articulation valve. It really hard to see in there because of the battery box but feels like the collar that goes behind the solenoid is still there. I will have more time tomorrow to look at it. Should the spool be able to be manually pushed?
I took the left transport lock pin out and the machine stayed straight for a bit but then moved enough I could get the right side pin out. After going back and forth about 250ft. on my semi curved driveway half a dozen times the machine drifted/articulated to the left about an inch (measuring by how much too long the pin now was). Is that an indication the articulation valve is sticking or the lock valve (for articulation) isn't working properly? I'm wondering if the machine was slowly drifting to the left that someone previous thought the solenoid was the problem and that's why it was removed? I wouldn't think it's normal for the articulation to drift but maybe it is? There is an extra lock pin that was left in the cab too. Only the right lock pin is original. The other 2 are just pieces of solid bar. I'm going to try putting power to the solenoid that's still there are see if it does anything. It's kind of seeming like it's a valve (hyd.) issue more than an electrical issue but I don't know the machine enough. Is there anything else I should check or test?
