Cat MM55SR excavator
Discussion in 'Compact Excavators' started by Fred, Sep 3, 2009.
  1. Fred
    Fred Active Member
    Jul 10, 2009
    31
    G'day all
    A local contractor in town has purchased a MM55SR painted up in Cat colours, but I think it may be a Mitsubishi, either way it is a grey import as E1G00xx prefix doesn’t come up as a good serial # with Cat dealer. My mate needs to find a few parts, his biggest problem is that the hyd don’t work when levers are used, but if you move control valve direct they with work. The electronic hand control system seems to be the problem, anyone had any experience with these machines or this problem?:confused:
    thanks in advance
  2. nork69
    nork69 New Member
    Feb 17, 2010
    2
    Part request mm55sr
    Is there a way to find part for this excavator? In usa or canada?? Nachi Hydraulic pump ? ? If someone know something please help us me and Fred. Thanks:notworthy
  3. gpap123
    gpap123 Well-Known Member
    Oct 13, 2008
    103
    Civil Engineer - Contructor
    Hellas (Greece), Europe
    A friend of me who owns a mitsubishi 5 ton excavator here in my country, replaced the electronic hand control to usual hydraulic controls because he could not find any parts. Of course he paid enough money...
    I also have a c a t graymm and the only way to find parts is to use serials from cat catalogue.
    So, you have to find out the similar to yours cat machine and match the parts serial. But this is also riski because serials do not always fit to the gray machines.
  4. cutting edge
    cutting edge Senior Member
    Mar 27, 2010
    575
    upper canuckistan
    That is a rebranded mitsubishi...as for the problem,is there a bad switch in the pilot enable lever perhaps?
  5. cutting edge
    Mar 27, 2010
    575
    upper canuckistan
    Ive seen that brand on smaller deere and hitachi excavators,mostly on valving though.
  6. farmer550
    farmer550 New Member
    Jun 18, 2013
    1
    london
    Hi I have the same problem with my 55. The rams operated by the electrics keep cutting out. Did you ever find a solution.
  7. gggraham
    gggraham Senior Member
    Feb 13, 2009
    306
    Licensed Heavy Duty Equipment Mechanic
    Does anyone know where you can get parts for an MM55SR? Cat is no help and have not been able to find any parts. I'd love to have any service info anyone has. I have a schematic for the MM55SR if anyone needs it.
  8. eclipse1290
    eclipse1290 Member
    Aug 21, 2013
    6
    Illinois
    Have you tried Maxis corp. Maxis.jp they are in Japan but have been helpful with my MM30SR
  9. gggraham
    Feb 13, 2009
    306
    No parts needed so far, joysticks stopped working but soldered a new ground on computer and all is well.
  10. wayneo
    wayneo Member
    Mar 27, 2010
    8
    vic australia
    I own a mm40sr and i have the same problem
    have found another thread on "mm30sr" full of people withthe same issues. as far as i can tell they are very simmilar electronicly. I have some error code sheets for these machines but am still at a loss for parts or help.
  11. gggraham
    Feb 13, 2009
    306
    Wayne I'd be interested in the code sheets if you can send them. I have schematics if you'd like them.
  12. wayneo
    wayneo Member
    Mar 27, 2010
    8
    vic australia
    that would be great. send me your email eddress i will forward them to you. & i would be very greatfull to know more about were to solder a new earth wire to on the circuit board. a photo or instruction on the process would be fantastic.
  13. wayneo
    wayneo Member
    Mar 27, 2010
    8
    vic australia
    my direct email address is kwfitzgerald@bigpond.com happy to help anyone who needs the info & code sheets i have.
  14. danielddp
    danielddp New Member
    Feb 23, 2014
    1
    Belgium
    Mm55sr
    Can you send me the schematic foor the MM55SR. I have a problem with my machine
  15. tmat
    tmat New Member
    Apr 9, 2014
    1
    Ballarat, Victoria
    MM55SR Controller Retrofit kit
    We have been supplying controller replacement kits for the MM55SR since 2009. The controller is a non-computer based box, converting the Mitsubishi joystick signals, matched to control the proportional valves. The retrofit is simple, basically bypassing the old loom and using only the existing valve and joystick connections. Please contact me info@imdynamics.com.au for details
  16. Tiaro excavatio
    Tiaro excavatio New Member
    May 15, 2014
    1
    Tiaro
    Steve here wanting to purchase mm55sr controller kit can I have contact number for you please
  17. PeterV
    PeterV Member
    Jul 6, 2013
    6
    Graham any chance i could get a copy of the schematic? I have the same problem with a MM55SR that the joystick controls wont work.
  18. deepsouthcc
    deepsouthcc New Member
    Apr 24, 2015
    1
    western australia
    Graham, we would very much appreciate a copy of an electrical schematic for the mm55sr if you can help thanks.
    deep southcc
  19. 2pitbulls
    2pitbulls New Member
    Jul 24, 2015
    3
    California
    I know this is old but I have the same problem , where did you find a broken ground ?
  20. kevin bordwell
    kevin bordwell New Member
    Nov 16, 2015
    2
    oly. wash.
    mm55sr controller retrofit kit, help!!!
    glad i finally found other people with the same problem, can you email me with a price and availability to the U.S. thanks kevin.
