Mcrafty1
Thanks Welder dave, I agree that putting the right material on those balls will be well worth it, Too much effort to go through to use to soft of a material, I'll get the rod you specified Thanks.If you are going to use weld build up it is worth spending more to get the build up rod that doesn't mushroom. It will last a lot longer and is made for building up parts back to size. Below is the best description I could find for it.
ESAB STOODY BUILD-UP LH-COATED | thr11414100 | ohcanadasupply.ca
Microsoft Word - Cse001.doc (gasandsupply.com)
