Queenslander
Iam trying to find the cause of high soot levels in our 2013 built D6R, S6T00779.
This is a tier 2 motor.. we had some discussion about it here...https://www.heavyequipmentforums.com/threads/d6r-track-wear.76755/page-2
The dozer had new injectors and heui pump about 200hrs before we bought it.
It had 5400 hrs on it at that stage, but before working it we had our Cat dealer give it a 6000 hr service...so changed every drop of oil, coolant, filters etc. as well as checking valve clearances.
We initially worked it for 40 hrs before changing oil and retesting.
The machine uses next to no oil, has very little blow by and runs very cool regardless of ambient temperature.
I later had aftermarket undercarriage fitted and while it was there I got them to check boost pressure with ET which came back within spec.
Certainly doesn’t lack power.
Fuel usage is around high 20s to mid 30s litres per hour.
Machine constantly blows black smoke, might not be considered excessive but it’s always there, particularly at low to mid revs.
Last suggestion on the test result is to check engine data..wondering if it is possible that horsepower has been lifted beyond the 195 advertised.
