- Joined
- Mar 11, 2012
- Messages
- 11,174
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
Your local hose man may not have the tooling for the reusable ends but your Cat dealer will. If the ends are very old and rusty, they may not be reusable any more.
I personally think Cat hose prices are quite reasonable for an OEM. Why not give them a call and get a cost on the assembly, 6K7407.
Checking with SIS dealer here in NY lists that hose as being $135, but has note of "indirect Replacement, contact dealer". But when I checked the "8S9355" number it comes up with a new number of "1650021" and that one appears to be just the hose with no ends and list for about $1.10 per inch. So if your ends are reusable and will work on the 1650021 hose that might be the way to go, all depends on what your dealer charges for hose assembly.
One nice thing is that hose appears to have a straight fitting on one end, hate it when they put an angled fitting on both ends as a minor error on assembly can make a hose impossible to install. Now if you have a good hose man he will make a note of the curve of the hose and assemble it so the natural curve of the new hose is in the same direction as the old hose! I also like to have them make up a hose per the build dimensions in hose book and not try to measure the old hose as sometime measuring the old hose can be off a bit and if the hose is fairly short even a fraction of an inch difference can make installation a bitch!
