Cat 225 LC rear main seal replacement project
Dapperdan16
New Jersey
Finally had some time this weekend to begin the rear main seal replacement on the Cat 225 LC with 3304 engine, question for Cat guys, does the coupler look to be in decent shape, is there a way to check for play or anything besides visually inspecting the rubber inserts? also does the whole coupler come off as one piece when I remove the allan head bolts? some pics below
boone
AL
Hey Danny, looks like you're making progress on the old girl. Is that an old Jubilee in the background?
Dapperdan16
New Jersey
I'm getting there, it's actually been enjoyable believe it or not, that is a Jubilee in the one picture, it's my fathers, he has 2 of them
Cmark
There's no real mystery about the coupling. If the rubbers looks soft or cracked then replace it. There is a classic part available for around $100.
It's fastened on by the two 12-point bolts through the rubbers. The ring of cap head bolts fasten the adapter plate to the flywheel.
etd66ss
Lockport NY
Hmm, I thought all 225's with the 3304 had a 2 pump setup? That looks to have the same pump setup as my 51U2607.
Dapperdan16
New Jersey
Thanks for the info Cmark, I'm definitely going to take the advice from you and Nige and order the classic part, the book is not to clear or "i'm not to bright" the book makes it sound like the coupler is attached to the adapter plate???? should I just remove the coupler by removing the two 12-point bolts you mentioned or remove the cap head bolts that holds the adapter plate on and they will come off together? Thank You.
Danny
Cmark
Well, if you're replacing the coupling you will have to remove it from the adapter plate at some point and it will be easier to loosen the two bolts whilst the adapter plate is still fastened to the flywheel. You will then need to remove the adapter plate for access to the flywheel bolts.
Dapperdan16
New Jersey
ok now I understand, thanks
Dapperdan16
New Jersey
Isn't that a pump in the center?
Anyways, thx for the pics!
yes, thats the gear type pump, so I guess it has three pumps technically. I believe the gear pump is just to send oil to the pilot system, the two axial piston pumps control everything else, boom,bucket,stick,track motors,swing motor etc What does your machine have?
Aren't "classic" parts a cheaper version? I'd check if the "premium" version is available and the price. I don't like to trust cheap grades of rubber to last in a hot oily area.
Cmark
Three hundred and odd dollars where I am. As always with this kind of decision, you have to balance the cost against how much work the machine is going to do against the consequences of a failure. In this particular case, I personally would go for the classic part.
I can't argue with that. And I suppose it's not a part that's likely to fail suddenly either.
Cmark
Exactly. And if the rubbers do fail it will still drive off the bolts. You would just notice a rattling noise when the engine stops and maybe some vibration.
etd66ss
Lockport NY
Mine has 3 pumps: http://www.acmoc.org/bb/attachment.php?attachmentid=58069&d=1456023466 http://i.imgur.com/55Gfpwb.jpg
Not the greatest pictures, but you can see my center pump in the second picture.
