GaryHoff
Its possible that you have a bad brake potentiometer, but not likely.
The pin out information I have, is different than yours. Please refer to the following.
**pot = potentiometer
brake pedal pot. pin A, wire 523, to pin 23 at travel controller - is 5v from controller
brake pedal pot pin b, wire 525, to pin 25 at travel controller - ground from controller
brake pedal pot pin c, wire 521, to pin 21 at travel controller - signal out from brake pot.
Make sure you have the wires in the correct positions in the brake pot. connector. As per your last post you said wire 521 is in pin B, and my information says it should be in pin c. Maybe you took out the wires for testing, and put them back in the wrong spots. The pins are easily moved, so its a fairly quick check.
If the wires are in the right positions, my logic says it should work, as you have power and ground at the brake pot.
Do you have any fault codes now?
