Gary N
I have a 1972 Case 580B backhoe with the hydro-static transmission and 188 series diesel engine (I believe). I just put in a new radiator, water pump, and thermostat only to find out that all my water goes straight from the radiator to the crankcase I don't think I overheated it when I was running it with the old leaky radiator that I always had to feed with water, but now I'm wondering. I looked on Case's website and see that the piston sleeves are o-ringed. I figure that I either have a blown head gasket, broken piston sleeve o-ring, or cracked block. I'm thinking if its a cracked block that I'm toast. But if its a head gasket or o-ring problem on a sleeve I have a fighting chance to get her fixed up. I'm hoping that a head gasket or o-ring would fail before the block cracks. Anyone know what the most common problem is when the water would rather be in the crankcase instead of the radiator, and what I might be up against? Appreciate any input and advice.
