Juskatla
As the pumpguy said, Tractorstuff, 800-428-8183
Shims that I got, $13.25, $13.25 and $17.00. Brake Band complete band replacement kit $50.00 each side. Disc and drum linings both sides $65. Balls, $3ea, etc. Side gear seal $15, O ring, carrier, $3
I am on the west coast of Canada and had a few shipments from Dale. All went USPS and even with Customs, they were at my door in 5 or 6 days. Would be a lot less in the US. When you order form someone like Dale, you can call and get advice and will actually get the right part sent. Dale stands behind his stuff and it can be returned if there is an issue. He has a large used parts supply for Case equipment and would probably have the bearing carrier. The cracking is not uncommon and has been mentioned on this forum in other threads.
