CA day in the life of a WABO scoopmobile Model HPD
allpinball
USA Washington
A day in the life of a WABCO scoopmobile Model HPD
Some random shots of an obscure loader at work....loading, fueling, raising, hauling, moving, and just posing. 50's scoopmobile model HPD with the 3-53 GMC diesel.
allpinball
USA Washington
more pics
Yutong
China
I really appreicate that Amercans could built their own houses.
That's amazing to me.
pistons
ohio
I bet a bad ECM will not ruin the day with that machine.lol (electronic control module)
Interesting machine that was probably before its time. If you look at some of the shorter reach material handlers on the market, they look to be from the same gene pool. Long pivot mounted boom, extended reach and dump height and maneuverability with the single rear pivot wheel. Of course the newer machines have pivot/crab/4 wheel steer instead of a single wheel on the rear end but the concept is the same.
Really like the picture of the machine running down the side of the road with the Jimmy pouring some smoke. Wear your ear plugs.:D
bigrus
Southern Queensland Australia
Joystick attendant
Nothing like the sound of a "jimmy"
Interesting machine that was probably before its time. Really like the picture of the machine running down the side of the road with the Jimmy pouring some smoke. Wear your ear plugs.:D
Great to see still working "GO the WABCO" :D ;)
Heavy Highway
Texas
That's a really cool rig!
I imagine its got to have some serious lead in the rear end to keep from tipping over, though.....
mitch504
Andrews SC
Why the struts beside the front wheel? They don't look like they're attached to the side well enough to provide much strength.
allpinball
USA Washington
The struts attached to the front wheels are not structural - rather they're part of the drive train. There are planetary gear sets in the hubs of the axle; the strut is splined onto the inner gear of the planetary in order to lock the gear in place and provide the gear reduction & associated transfer of drive torque to the frame of the machine.
A side benefit is these struts can be easily removed, which effectively disconnects the entire powertrain (including the differential) from the wheels; this was to allow towing of the machine; there is a towbar that can be attached to the single wheel at the back of the machine. In this configuration the machine could be towed on streets at moderate speeds.
allpinball
USA Washington
re: weight in rear
Yes, the entire back end of the machine is very heavy construction (akin to a forklift) to provide a counter balance to the boom. The boom can lift 8,000-10,000 pounds before it starts feeling light on the back end.
A drawback of this is the back end sits very heavy on the single rear wheel, which makes it prone to finding the softest earth available. I've learned that on several occasions.
It has power steering in the rear to make up for the heavy weight back there.
mitch504
Andrews SC
That is a cool setup for towing:D
iceberg210
Seattle (Newcastle/Auburn) WA
Awesome machine! I love seeing those old machines, someday I'd love to run one, looks like a blast!
Years ago in the sixties I think my grandfather took an even older Scoopmobile that had a mast on it instead of that nifty boom. They took the bucket off and put a set of forks on it to make for their first forklift. It's steering wasn't power and was just a rod that ran from the back wheel up over the operator's head down to a handle that the operator worked. Apparently driving over a pot hole was akin to dislocating your arm if the wheel hit the pothole wrong.
At any rate anyone remember that sort of Scoopmobile? I've only heard stories and never seen pictures of the old beast, as it was sold long before I was born...
Also anyone know what happened to the Scoopmobile company? WABO I suppose?
Thanks for the information...
allpinball
USA Washington
  • re :Also anyone know what happened to the Scoopmobile company? WABO I suppose?
My mistake putting WABO in the title instead of WABCO (forum will not let me edit the thread title).
WABCO is short for Westinghouse Air Brake Company. My scoopmobile has data plates indicating it was built by WABCO....so the scoopmobile design and/or manufacturer may have been bought by Westinghouse.
Other names tossed around are Wagner and MixerMobile; "scoopmobile" is more a model name than a manufacturer name.
Some history:
http://www.vannattabros.com/iron29.html
http://www.vannattabros.com/road8.html
allpinball
USA Washington
More scoopmobile at work
For the scoopmobile, the job is never done.
rabbit
Washington
Plumbing and Exavation Contractor
Scoopmobile
A contractor here has two of those scoopmobiles.. One big and one bigger.
:usa
