I had a similar issue with my T300. Most times the panel would turn on then off. Sometimes it would start and would shut off immediately. Other times it would start and run for a bit then shut off. Code 76-73 would display along with "Reply" on the left panel. The fact that it would start and run sometimes lead me to believe it was not the panel. Plus these panels are spendy so I decided to do some wire testing. I pulled the plugs out of both panels and checked for continuity between the panels and to see if the wires were grounding. I also pulled the J2 connector off the controller and checked there as well. I found a few wires that were going to ground so, I started tracing the harness. There is a 16 pin connector near the hydraulic fill tube under the cab. When I moved that connector, I was able to turn the panel on, start and run the T300. When I wiggled the connector again, it would shut off. What I found was the harness from that connector to the J2 connector on the controller wore through just inside the rail and some of the wires were shorting to ground. I ran new wires from the J2 connector on the controller to the 16 pin connector next to the hydraulic fill tube. There is a slot in the rail near the cab strut on the left side that I was able to lift the harness and see the worn wires. The hardest part of the rewiring job was seeing the wire numbers to make sure I repaired the right ones. After the repairs, I stuffed some foam under the harness to hopefully prevent more damage to that part of the harness. So far I have had no issues. This was also the cause of a seat bar fault we had a year or so ago.
