DrJim
- Joined
- Feb 19, 2011
- Messages
- 172
- Location
- Oak Ridge TN
- Occupation
- General Dentist, including Implant Restorations
Now, Willie, a couple of questions for you. You remember that I found the spacer just laying there, but. . . there is no telling if there was another spacer or washer added to that one, in between the bracket and the pump block. The question is, should be use the one spacer, and pull the mount bracket up tight, should we make up spacers that mostly fill the gap first, or should be maybe add a washer-spacer to fill maybe half the gap and pull it up tight from there? Of course, we would select the optimum length bolt to engage as much of the threaded hole as possible without binding or bottoming.
Another Willie question: I don't want the bolt to work its way out, but if we use red threadlocker and the bolt breaks again, we are back to the same problem of trying to retrieve the broken segment. I am inclined to skip the threadlocker and tack-weld the edge of the bolt head in a very small spot. That will keep the bolt from backing out, and if the bolt breaks, the tack could be ground off, the head would fall off, and the bolt could be more easily retrieved.
This would also prevent the broken head-end of the bolt from finding its way under the plastic fuel tank, where it could rub a hole. Whaddaya think, Ol' Morooka Man?
