DrJim
- Joined
- Feb 19, 2011
- Messages
- 172
- Location
- Oak Ridge TN
- Occupation
- General Dentist, including Implant Restorations
I have set out to re-seal my spool valves, re-build the float detent mechanism, and refurbish the pintle arms & torsion bushings. I started out by having a helper thoroughly clean the innards of the machine, with the cab tilted up.
When I started to work, I spied a part--a bushing or spacer of some kind--lying on the top of the "case" immediately under the pump, in the area beneath and slightly in front of the right side pintle mechanism. Here is the part, and the area in which it was found.
