bobcatmechanic
you do not have to remove the engine you can get it by either reaching over the top of the hydrostat or under it use a pry bar to get hte pick up tube out and then replace it put the screen in first then the gromet and then push the 90 degree fitting in if you try to put the gromet and fitting in together assembled it will not go or you will spend twice as much time to force it in
