bobcat 773 help
Discussion in 'Skid Steers' started by wadman, Mar 5, 2006.
  1. wadman
    wadman New Member
    Mar 5, 2006
    1
    south carolina
    My bobcat 773 stalls and seems to get air in the fuel lines. Im am not a diesel mechanic so anyone who can tell me where to look for this problem would be a big help. Someone told me that alot of bobcats develop a bad grommet in the fuel tank and that can cause this. Is this hard to fix?
  2. Jeff D.
    Jeff D. Senior Member
    Nov 9, 2005
    1,280
    MN.
    Wadman,I'm not familiar with the 773,so the "grommet" thing may be the problem.
    I had a similiar problem that slowly got worse with my Bobcat.After sitting a few days it would fire right up,but then die after about 2 seconds.Then it was VERY hard to get restarted again.If it had just been running awhile,it would fire right up,and wouldn't stall at all.As time went on it was harder and harder to get started cold.It acted like air in the lines,but it turned out to be the injection pump.It was just plain worn out.There was too much clearance between the close fitting parts.
    Hopefully that is not your problem,the pumps are expensive.If you truly have air in your lines then it probly isn't the problem.I've a Isuzu 2AA1 diesel in mine.In mine the fuel is drawn up the fuel line,out of the top of the tank,it then goes into a seperate mechanical lift pump,then it's pushed through the filter assembly,and finally into the injection pump.Mine doesn't have a grommet in the fuel tank,other than the one sealing the fuel/fuel return lines, where they enter the tank(and they couldn't cause a starting problem).I'm not sure why yours would have a grommet inside the tank either,but it may have one regardless.
    If fuel level affects this problem,then it probly is inside the fuel tank.A fuel line leak between the tank and engine would most likely show up with diesel fuel leaking out also.Without any signs of that,I'd next look for anything that could restrict fuel flow(pinched line,plugged filter)or possibly a defective fuel pump(if it has a seperate one).My lift pump has a lever mounted to it too manually operate it.If air is in it,it feels mushy when moved,and firm when the system hasn't any air.
    I know it's not specific info for your model,but maybe it'll help anyway.
    Good luck!!
  3. itsgottobegreen
    itsgottobegreen Well-Known Member
    Nov 1, 2005
    180
    Maryland
    Check your fuel primer bulb. The nice thing about bobcat when you run out of fuel its easy to reprime. Only problem is the primer bulb can crack at the pipe clamps on the fuel line. Which lets in a little air.
    There is a little knob on the side of the injector pump. Turn it so it is open. Then squeeze the the primer bulb if you hear air flowing thur the injector fuel lines and in the return line. Then you know its the primer bulb or the fuel line.
  4. skidsteer.ca
    skidsteer.ca Well-Known Member
    Jan 27, 2006
    62
    Contractor
    Nw Ontario
    The best thing to do imho to check for air getting in your fuel system is to remove the fuel return line and submerge the end of it into a pail of fuel. Start the engine. If you have a air leak the bubbles coming out of the return line will be quite noticable. Try moving your rubber lines, etc to see if it makes the bubbles size or amount change.
    Ken
  5. arcfiddler
    arcfiddler New Member
    Mar 14, 2007
    3
    Brazoria, Texas
    Air in fuel - Bobcat 753
    I have a Bobcat 753, approx 2000 hours, and a similar problem with getting air in the fuel system. The machine runs like a new one on the first 1.5 to 2 gallons. after that, it's game over. I have replaced the primer bulb and all fuel hoses downstream of the bulb.
    Top off the tank, squeeze the buld and prime the fuel filter, crack open the bleeder, hit the key, and back in action for another 2 gallons.
    The problem remains after the new hoses and bulb, so I suspect as in one of the previous posts there must be some sort of pickup tube in the tank that is cracked...or maybe its that one last factory hose from the bulb to the tank.
    Has anyone got into one of these tanks before to know if there is a pickup tube?
    Anyone out there have a fuel system schematic they could pdf my way?
    I'll be tearing into my machine this weekend...if I stumble across anything I will revise my post to detail what I have found.
    Thanks,
    Mike:beatsme
  6. arcfiddler
    Mar 14, 2007
    3
    Brazoria, Texas
    Problem Solved - Air in Fuel Bobcat 75
    Per my post last week, upon inspection I found that the fuel is drawn from the top of the tank via a dip tube. Factory length is 9 inches plus a screen.
    My machine's dip tube had rotted off at 2 inches (which evidently equals 2 gallons). New hose, screen, and grommet came to less than $25 including shipping.
    Back in action.:)
  7. digger242j
    digger242j Administrator
    Oct 31, 2003
    5,889
    Self employed excavator
    Southwestern PA
    First, Mike, welcome to the forums! (It doesn't look like anybody else bothered to do that. I think Countryboy is chairman of the welcoming commitee. :cool2 I'll have to have a talk with him...)
    Thanks for the update on your machine. Even though nobody else apparently had the answer to your question, now that you've found it on your own and shared it, we all have that answer. :thumbsup
  8. Countryboy
    Countryboy Senior Member
    Jun 8, 2006
    3,276
    Load Out Tech. / Heavy Equipment Operator / Locomo
    Georgia
    Aww shucks, my bad Arcfiddler........Welcome to HEF! :drinkup
    And thanks for ruining the surprise DIGGER!!! :mad: Now he knows that he is "Welcome" and the party ain't till tomorrow. :D
  9. hvy 1ton
    hvy 1ton Senior Member
    Jul 24, 2006
    1,296
    Lawrence, KS
    I have had that problem with diesel equipment several times. Last year with my JD front mower. I had rotted pick-ups in both tanks. They broke off around 3 in so every time i went on a side hill no more lawn mowing. The downhill tank would work and the uphill wouldn't it, so took awhile to figure out. :bash
    I'm just glad I was sure it wasn't the injection pump.:drinkup
  10. CM1995
    CM1995 Super Moderator
    8,238
    I had the same problem with an 853 bobcat. First time it was a clogged screen in the fuel tank - made the engine run sluggish but it ran. Second time it was the pick up tube, it had rotted off.
  11. mudflapmax
    mudflapmax Member
    Mar 21, 2008
    5
    Texas
    Where did you find access to the fuel line into the fuel tank in order to replace the little tube? I can't find any access when I raise the cab, nor from the rear or sides. ???
  12. Countryboy
    Jun 8, 2006
    3,276
    Georgia
    Welcome to Heavy Equipment Forums mudflapmax! :drinkup
  13. arcfiddler
    Mar 14, 2007
    3
    Brazoria, Texas
    On my machine, once I raised the cab, I had to nearly lay on my stomach with my feet hanging out over the bucket. Directly in the center of the machine there is some sort of red gizmo...it might be black until you do some cleaning in there. Just behind that, slightly under the engine you should see the black poly fuel tank. I believe mine had two rubber grommets with 90 degree push in fittings. The lines ( one feed, one return)come off the top of the tank and run rearward under the engine. I would reccommend putting your machine out side, roll the cab, and give her a good cleaning with some engine degreaser prior to popping out the grommets. I used a flat blade screw driver and a steady hand to pop the grommets out...the dip tube / screen will follow.
    Its been awhile since I did this, so the description above may be off a bit, but should be close enough to get you looking in the right place.
    Headed out of town in a minute and in a hurry...otherwise I would e-mail you a photo...my apologies in advance.
    Good Luck!
  14. jnstrawn
    jnstrawn New Member
    Mar 25, 2008
    1
    Vicksburg, Ms
    I have the same problem. Did you have to remove the engine to access and replace the grommet and filler tube at the tank? Or is there another way to get to it?
  15. Countryboy
    Jun 8, 2006
    3,276
    Georgia
    Welcome to Heavy Equipment Forums jnstrawn! :drinkup
  16. bobcatmechanic
    bobcatmechanic Senior Member
    Mar 27, 2008
    429
    bobcat mechanic
    kansas
    the fuel pick up tube is located under or behind the hydrostate which is under the cab in order to lift the cab there are to bolts in the front corners of the cab inside remove these and lift the cab up then take a mirror and flash light and look behind or under the pumps which are straight in and you will see 2 hoses one is the fuel delivery hose and the other is the return pull the squezz ball to the back of the machine then pull on the hoses under the cab and you will determin the right hose to pull after you pull it you will have to put a new pick up tube on and new gromet put the tube together then put the gromet on the tube after that put the screen in and then put the rubber gromet in the tank opening you have to put the gromet and fuel pick up tube in together and then you put the metal 90 degree fitting in after you get the gromet in the tank you wnat it all put together before you start putting anything in the tank but thats about the jist of it i know this because i work for a bobcat dealership and do this on a weekly basis any questions and ill be happy to answer
  17. bobcatmechanic
    Mar 27, 2008
    429
    bobcat mechanic
    kansas
    you can put the pick up tube which is located under the hydrostate under the cab which you have to lift the cab to get to it you pull the old pickup tube out and then reassemble the tube with a new one and then put the screen in with the gromet on the tube and then get the gromet seated in the tank after theat you can stuff the 90 degree fitting in and your done pump up the fuel system and your good to go i know this because i work for a bobcat dealer ship and do this on a weekly basis any questions and ill be happy to answer them
  18. bobcatmechanic
    Mar 27, 2008
    429
    bobcat mechanic
    kansas
    the pick up tube is under the hydrostate under the cab which the hydrostate is the pump straight in when you lift ythe cab and look straight in you pull out the feed line and its on the bootom of it pull it off and get a new one then reasswmble it put the screen in and then get the gromet in the tank then you can simply put the 90 degree fitting in and your home free you will have a cramp and scraps buy the time your done its a tight fit and awkward to do but it can be done with everything still in the machine you do not have to remove the engine or hydrostat to do i know this because i work for a bobcat dealership and do this on a daily basis
  19. mudflapmax
    mudflapmax Member
    Mar 21, 2008
    5
    Texas
    Bobcat fuel supply repairs
    Thanks to arcfiddler for the inspiration to keep cleaning and looking for the fuel line inlets when I was just about ready to give up. I only wish I had read 'bobcatmechanic' before I spent all day on this repair job. He is right-on with his description of location and technique. Thanks very much for all the help. My next project is to stop the creep i'm experiencing when I should be idling. I see under the cab two linkage bars with adjustment slots secured by bolts. Is it that easy to fix the problem?
  20. mudflapmax
    mudflapmax Member
    Mar 21, 2008
    5
    Texas
    Walking Bobcat
    I have a 773 Turbo that likes to creep on its own when it should be idling and sitting still. Has anyone else had that problem?
