Similar Cat, 931/941, Deere 555G or step up to 605 for rear engine(is a Liebherr) Then there are Liebherr, and of course Case. I would seriously look around, find a decent median sized crawler for loader work, if need a hoe buy a hoe as these do not do all that well being heavy, awkward and the hoes are an after thought mainly for open country work. Would need as noted counterweight without it or with it rear undercarriage receives considerable added force and trauma from daily use. This unit basically needs rails, he has a engine sitting there for a reason that will need be swapped along with the inconsequential hoses, fluids, incorrect for app changed parts and gaskets, then you would need to check all the hydraulic lines/hoses all those pieces needed removed to just get at the engine. I could rationally see $18,000 WITH the hoe but no more as you will end up spending at least half that again getting it fully up to speed.
