580sm
ivi
prescott az
Hello All, I am looking for information on the procedure to shim the crowd boom to the main boom. There are shims that go between the two, and one large nut that holds the pin in. the pin has a shoulder on it where the threads for the nut are. i had to replace the crowd boom due to the oem boom breaking.
580 super m series 2
alrman
QLD Australia
Welcome to HEF @ivi
The parts book does not show shims in that area. If the clearance between the boom ears & dipper seems excessive you could install some.
Curious though, where did your old boom break?
Did it happen in one go, or was there a crack that got worse?
Any pictures?
ivi
prescott az
i ordered a couple of number 19 or 20 from the case dealer in my area. they designated them as shims. I know they show them on the outside of the main boom but they are cupped and fit perfectly on the crowd boom between the two booms. i figured they go there. I do have to mention that my parts diagram doesn't show numbers 37&38 though. as far as the boom breaking, it broke right at bore for the pin .. number 16. didn't really see any cracks before hand. right in that area is always covered in grease due to greasing that pin. ill see if i can post some pictures tomorrow for ya . there is a lot of side to side movement between the two booms at that hinge point , so i think there has to be some sort of shim to take up the slack. i cant see running the down so tight to take up the slack due to the main boom being made of ductile iron.
