580ck
Gonna try and start from the beginning but want to say I appreciate all input.
580ck 188 D motor. When I bought it, the rad was leaking and seemed to not be running on all cylinders. I changed the rad, bought a used one and installed an external cooler to save money. Also installed a mechanical temp gauge. After some use, there was coolant in the oil, blown head gasket. I pulled the head off to change it then noticed the seized valve and bent push rod. It was just floating around. I bought a used rod and some used valves. My friend ground down the valves to resat them. I have a good service manual so we followed the manual when we did any repairs. The bent rod and seized valve were in the cylinder closest to the fan. Also noticed that the second cylinder had damage to the head, score marks. Rather big ones. The guy I bought it from told me that one cylinder had a piston and sleeve changed and by seeing the score marks in the head, it was easy to see that it was cylinder two. Got it back together and no leaks but still not full power. A guy came out to take a look, Phil from this forum and said it looks like my valves need to be adjusted, he was right. Thanks Phil. So now it is running good, full power. That was last year and got to use the machine a bit. Then this year, used it for a bit when all of the sudden the coolant starting shooting out the rad. That happened after using it for an hour or so and only when I parked it and it was idling. So this time there was oil on the inside of the rad cap. Another head gasket. So off it came only to find the bolts were not tightened to spec, defective torque wrench. There was coolant across 3 cylinders when we opened her up. So I assume if I buy a new head gasket and new torque wrench, it should be good to go. Not the case. About 10-15 secs after firing her up, coolant comes out the rad. This time, no oil in the rad cap. So we remove the injector on cylinder two and not coolant coming out the rad. I put the injector back in and coolant starts to blow out the rad. So I now know it is that cylinder that is giving me the problem. Pressure is getting from the cylinder to the cooling system. Everyone says the head is notoriously tough so I want to rule the head out. My question is/are: Is there anything to do to diagnose before I pull the head off? When pulling the head off what should I be looking for. I am not a mechanic and my friend helping me is a "backyard mechanic" and never worked on diesel but is good and getting his hands dirty and trying to figure stuff out. I appreciate all the help here and look forward to some more feedback. Thanks
