Willie, We live in a parallel universe. We both have M tractors, We both have the TD7E Dozer, and we both have a 580K and I'll bet your universe isn't more than a couple hours away. Pretty strange coincidence.
The OS-6 is just an M made for use in an orchard. It has shorter rear tires [mine are the 14.9 x 26], shorter steering set up, short air intake and short exhaust that makes it a good rig for working in the woods. Mine has a hand clutch so you can drive it standing up like a chariot so it's easy to jump on and off. It's got a lot of low end, too. I had the front wheels 2 feet off the ground pulling some big logs with a chain from the drawbar. Here is a picture of one I found online. I don't know how to post pics anymore since they changed it over. If someone wants to take the time to explain it to me or direct me to the instructions, I'll post one of mine. I think mine is a 1948.
McCormick-Deering OS-6, restored version captured at a California antique tractor show
Model history
Model introduced 1944
Model discontinued 1953
Model status Discontinued
Preceded by New model
Engine Specification
Engine make International
Engine model C-248
Fuel type gasoline
Power hp 37 belt, 32 drawbar
Governed rpm 1450
Displacement cu in /(litre) 248 ci
No. of Cylinders 4
Bore in (mm) 3.875 in
Stroke in (mm) 5.25 in
Cooling system water
Naturally aspirated, Turbo or Supercharged NA
Transmission Details
Transmission type sliding gear
Gearbox make International
Forward 5
Reverse 1
Drive 2-WD
General Data
Linkage Category drawbar
Tyre Sizes (std/options)
Front 6.00-16 4-ply
Rear 14-26 6-ply
Tractor Dimensions
Length (inches/metres) 133 in
Width (inches/meters) 60 in
Height (inches/meters) 62 in
Weight (nominal) lb/kg 4600 lb
Turning circle (nominal) inches/meters 25.5 ft
Wheelbase 76 in
Other info
Factories Rock Island, Illinois,
USA
Plow rating 3-14"
Nebraska Tests No. 355
Approximate Cost new in (year) $2335 (1951)
This box:
view · talk
The
McCormick-Deering OS-6 was an
orchard tractor built by the
International Harvester company from 1944 to 1953 in Rock Island, Illinois,
USA.
Contents
show]
Model historyEdit
For Company history see
Main article:
The McCormick-Deering OS-6 was basically the
O-6 without the shielding. It retained the lowered air intake and exhaust, headlights, seat, and controls.
Timeline Edit
- 1940 - McCormick-Deering W-6 gasoline-powered standard-tread tractor replaced the W-30
- 1940 - Later in year, O-6 orchard, based on W-6, replaced orchard version of W-30
- 1944 - OS-6, without the shielding of the O-6, added
- 1946 - Brand name shortened from McCormick-Deering to McCormick
- 1953 - OS-6 discontinued
Factory locations Edit
- Farmall Works, Rock Island, Illinois, USA
Specification Edit
See Infobox for basic details
- Standard tires
- Front: 6.00-16 4-ply (1946)
- Rear: 12-26 6-ply (1946); 13-26 6-ply (1948); 14-26 6-ply (1951)
Variations and Options Edit
- Optional tires
- Front: 6.00-16 6-ply or 6.50-16 4 or 6-ply (1946)
- Rear: 13-26 or 14-26 6-ply (1946)
Serial Numbers Information Edit
Year Serial no. run
start[1] Serial no. run
End[1] Number Built Notes
1944 OBKS6313 9495 Serial range includes W-6, WD-6, O-6, OS-6, ODS-6, I-6, ID-6
1945 9496 14152 Number built included with
W-6
1946 14153 17791
1947 17792 22980
1948 22981 28703
1949 28704 33697
1950 33698 38517
1951 38518 44317
1952 44318 45273
1953 45274 45843
[2]
A handsome tractor!
Born in 1956, the IH dealer was 1/2 mile from home, mother kept the books. Most models were represented in new, or service. Without the badge, I'd have assumed yours was a W-6. I've always preferred the low center of gravity models.
In recent years we have gotten into antique tractor pulling. For reasons I don't understand, the utilities don't do as well as row crops. Mine has no added weight. Seth does remarkably well with his M. He is licking his wounds, last fall a 560 found its way into his weight class. He took second place.
ShareMore Info
See full size image
Added by
Edrob Posted in
McCormickMcCormick-Deering OS-6User:Edrob/McCormick-Deering OS-6
