Axl
- Joined
- Nov 19, 2011
- Messages
- 12
- Location
- Eastern Washington
- Occupation
- Power Plant Operator / Repair Shop Owner- Mechanic
First, I will have to say this is a great forum. I have been a heavy equipment mechanic for about 26 years now and I find a lot of good information here for even the advanced mechanic. Now, I am looking for some help on an older 580B with a Rockford power shuttle that has me totally beating my head on the wall! :Banghead A friend of mine brought me this machine he purchased with a the forward and reverse clutches burned up. We split the machine in half and replaced all the bearings, seals, and anything that looked questionable from the torque convertor to the manual transmission. When assembling the clutch packs, all were bench tested with 150psi air pressure. I had to replace all the springs in the clutch packs. This took some research. I did find some that have the exact number of coils other than the diameter of the spring was a little heavier. They worked great and I did not have to cut them down. I think the price for both sides was around $50. If anyone is interested I could dig my receipt out and tell you where I got them. The trouble I am having is that both clutch packs want to engage at the same time. The pressures on the convertor, lube port, and clutch pressure port fall within spec. The case was bored and sleeved where the cast rings from the main shaft normally show wear. I removed the control valve assembly and dye penetrate checked for cracks. Nothing showed up. I tested the clutch packs through the top plate ports on the shuttle valve and both operated normally. I got to wondering if I missed something on the shuttle valve assembly so I removed the trans/differential. The cast rings were still in new shape, nothing broken. Wondering if the rolled ports inside of the shaft could be leaking by I replaced the main shaft. After reassembling the machine nothing changed. Since there are no individual clutch ports or no test ports down stream on the spools I replaced the control valve assembly. No change. I am at my wits end! I have rebuilt the twin disc in another machine and found it very straight forward. If anyone has and idea of what I may have missed your reply would be most welcome. The trouble with these older machines at the dealer is most of the older mechanics have retired. The new younger guys do not have much if any experience with these machines. I have tried talking to the service manager at our Case dealer and he has very little experience trouble shooting this model. The best he can say is bring it in.
