Hello everyone,
This is my first post so go easy on me. I have this machine for farm use and i am trying to take my time and do the brakes right. Several questions i have about the process:
1. Do i have to drop the transaxle to get the inner brake housing off? Evidently the seals are bad on the side the differential lock is mounted to.
2. Can i have the inner brake housing resurfaced. There is some scoring but the grooves aren't deep.
3. The left side brake was working but grabbed badly and sounded like metal against metal. When i removed the outer cover for that side there was plenty of dust but the brake discs were ok. A mechanic told me the springs on the bendix type discs would weaken over time causing the grabbing but that doesn't explain things.
It has the dry type brake with the vent hose connections on top and the actuators cylinders are in good shape.
Thanks in advance for any reply.
