Dougie G
I am quoting Nige's comment from the thread I posted a link to.
"There is no valve shown other than the control valve over the rear axle which is installed in the gap between the 2 hoses at the top left (ringed in red). I would check where the hoses come out of the engine block, shown as Area B, just to make sure that nobody has sneaked a shuftoff valve in there. If you find no valve then the next step would be to disconnect the feed and return hoses at the cylinder block and try to blow through one of them. It should blow coolant out of the other. If it doesn't then either your control valve that"
Did you look for that valve over the rear axle ??
Like Delmer says make sure the engine is actually getting hot, not just a little warm to the touch but after working hard for half an hour you should not want to keep a bare hand on the side of the block.
This is one of those time a cheap IR temp gauge could pay for itself fast. Not sure if you guys have Harbor Freight up in BC but something like this: https://www.harborfreight.com/infrared-thermometer-93984.html
I have to remember to pick one up for at home now that I don't have access to the one we had at the shop!
If engine is getting hot but the heater hoses are just a little warm I would say as other have that something is restricting flow. Might just have to hook a garden hose to one of the heater hoses with the other end unhooked and go through the system one step at a time till you find the restriction, be it a valve not working or plugged core or kinked hose.
Hi, I do have an inferred thermometer, that is how I checked the hoses and the block. After idling for 45 minutes on half idle, I think the block was at 65 to 73 degrees or so and so were the hoses. That seems too cool, but maybe it needs to be worked to heat up. So tomorrow I'll work it for a while and then check the temperatures on the block and the hoses. I did look at the valve over the rear axle, it has a cable going to it and is a plastic type valve. I was by myself so I had no one to move the control inside for me but I moved it myself and went back and looked and it seemed to be moving as it should, but then my flash light went dead.
