Dougie G
Hi, I have a 98 416C IT backhoe. I purchased used. It was well maintained and runs good. My heater in the cab only blows cold air. There is a dial on the side panel for temperature control and a hi low switch for the fan. Trouble is it only blows cold air, even when the dial is on high. Its winter now and gets a bit cold in the cab. Is there a switch somewhere that could be shut off or could it be the thermostat is too cold for this climate. I have looked around the engine and above the rear differential and didn't see a ball valve or switch. I can see the cable coming from the dial that controls the heat, and it seems to be working like it should. The machine spent most of its life in a warmer climate. I don't have a shop manual any more, it was lost in our house fire. Thanks
