Ricardo Cotte
Good morning all and Happy Holidays!
My 310SJ every once in a while doesn't move forward or reverse when initially started. Even after a few minutes.
If I let it warm up around 10 minutes at a slightly higher rpm than idle (1200 rpm) it resumes normal operation during the day. Also, if it coasts down in gear it will engage a bit sooner.
My weather here is warm all year long, I have changed the filter and top off oil in the ZF transmission and it improved for some time.
The question is: Is there a possibility of the pump draining and needing to prime up somehow? Could it be hardened seals and other stuff that needs to warm up to operate and seal pressure somewhere? And the most dreadful...is it a sign of impending teardown and overhaul?
This TLB has 3400 hrs and it is a 2012.
Other than that everything else tranny related works as advertised.
Thanks much for your comments .
