gyman98
Good morning everyone, I have a 2004 kenworth t300 that I bought with a blown motor. I put a new (used)c7 cat engine in, I swapped the ecm, every sensor and wiring harness including injectors from my original engine.
Everything seems to work well and it runs great but my abs light is on. No idea if it was on before as the truck didn’t run.
I have a plug-in hanging down near the drivers side bellhousing that I have no idea where it goes. It has a factory tag on it that says TC sensor. I don’t remember unhooking it, not sure if it was ever used.
Would this cause a abs light? If so where does it go? The timing sensors behind the air compressor plug into the engine wiring harness
