1967 C180 cummins need a set of fuel rails
1693TA
Farmington IL
FAA Radar Engineer, (Retired)
I had them make up some lines to interconnect my diesel timing light and they work well after the air is purged and #1 is firing.
crane operator
sw missouri
I finally made it by the engine core place yesterday. Unfortunately, he does not have anything that would replace your old cummins lines. He could only recommend taking the old lines to a injection pump shop and having them copy them.
mekanik
Canada's Northwest
I have worked on Cummins engines that had the flanged injectors but I don't recall how the lines connected to the injectors, compression fittings?
Could you make lines up from 1/4" and 3/16" brake line and fittings?
