Hartlyboiy
I found myself ill-equipped to handle my latest adventure with my new to me Genie Z45 when she started pumping anti-freeze through a corroded spot on my water pump casing. Have seen a lot of leaks on various water pumps but none coming out the side of the casing. It's a 2005 with less than 600 hours but... It has a Ford engine and runs on propane so a net search tracked down another pump but I found that with all the manuals and such that came with the lift, there was none for the engine itself. Feedback from the serial number indicates I'm dealing with a Ford LRG 425 EFI. The PDF manual I found tells me about how to change hoses and such but is silent on changing out the water pump itself. Frankly it doesn't appear all that difficult and we'll swap it when the new one gets here, but the thought is there must be better manuals out there.
Has anyone found a good LRG 425 EFI manual they rely on?
