Wally0
The supply hose to the hydraulic pump collapses when truck is running. Could it be that the filter inside the holding than is clogged and if so is there a way to clean it. I Checked the hydraulic fluid level in the tank and its at a normal level. There also seems to be fluid in the return hose to the tank. The fork lift works normally but the steering makes a lot of noise.
It is an old Eaton-Yale lift truck, 1980 I think. the model number is GLP050RAJUAS086.
Does anyone have any ideas.
