ya gotta ask the "dumb" questions sometimes
54j
perth
on my old 1972 d5.the fuel pressure gauge.......is that related to the volume of fuel in the tank? ie full empty? appreciate you setting me straight.
bobin35
indiana
No it is the actual fuel pressure measured at the pump,if it goes low enough in the tank it will go down on the gauge but by then its to late,your out of fuel.
54j
perth
thank you.that makes sense.i was way low in the tank and i noticed the fuel pressure gauge in the red...thanks
Komatsu 150
Northern Illinois
The biggest reason they used to install fuel pressure gauges was to monitor condition of the fuel filters. Once you get used to what is normal on the gauge it is easy to tell when filters are getting plugged up long before there is a problem.
On edit: if the fuel pressure is in the red and engine is still running, there is generally something else going on besides just low fuel, maybe plugged filters or a bad pump.
54j
perth
ok.thanks for that..i'll take it a bit more seriously and look into it.......thank you very much
