Bala
One of the machines i look after is a new Holland LB90 backhoe and it has been running ATF for most of its life,
It is not the correct oil but the trans runs fine,
Do i change it out for the correct oil, bearing in mind i would have to fill and drain a few times and then still probably have a bit of a mix,
or do I just leave it on ATF?
