Wrecking Ball
farmerlund
North Dakota
Farmer/ excavator
Does anyone have or know of a 4000lb or so, wrecking ball for sale. looking for a used one with a good price. How big of one could I swing with a 210 size excavator? Does shape make a difference? Seems like every summer I get a job where it would be nice to have.
Any of you guys have experience using one on a excavator?
Scrub Puller
Yair . . . .
Guday farmerlund.
I don't have time to look around but I recall there was a thread a few years back with an extensive discussion about wrecking balls size and shape and what all . . . it might pop up a search.
Cheers.
Graham1
Hampshire, UK
Postage may be a bit steep!
Gives you an idea what weight Europeans reccomend. More than double what you are looking for, so should be no trouble to handle.
https://www.finn.no/b2b/construction...nkode=89700688
1 piece 4 tons, 3 pieces 6 tonnes available for delivery end of April.
3 pcs 5 tonnes available for delivery in May.
Mineralteknikk AS supplies high quality crushing balls in several sizes.
Rockmonster bullets are produced in a tough specialty alloy that prevents cracking and / or splitting
Of the bullets.
Produced in Europe with 2 years warranty
Standard stock size:
4 tonnes ± diameter approx. 990mm. About. Machines up to 25 tonnes (depending on drawstring)
5 tonnes ± diameter approx. 1070mm. About. Machine up to 35 tonnes (depending on the drawstring)
6 tonnes ± diameter approx. 1130mm. About. Machine 35 tonnes and upwards (depending on the drawstring)
Other sizes on request
Rene Landmark tel. 90238887
Nils Ivar Reiten tel. 91797089
Arne Kenneth Øvstebø 90122419
Tones
Ubique
If you can't find a ball a counterweight off a forklift works well particularly the type with a hole were the air gets to the radiator. All you have to do is rap a chain through it and tie it to the machine and you're in business. :)
Bls repair
S E Pa
Equipment operator,mechanic
Craigslist Philadelphia in wrecking ball for sale . Need to call to get info
farmerlund
North Dakota
Farmer/ excavator
Thanks for the replies. I like the counter weight idea. was looking around my junk but nothing solid enough. I am not in a hurry, so I can keep looking on the auction sites to.
Junkyard
Claremore, OK
Field Mechanic
KCMO Craigslist has one too. Just get Homer Simpson to ride a cable choker haha
mitch504
Andrews SC
Used to use a 4-5 ton ball w/ a Kobelco 210. It worked very well, though we didn't swing it, we picked it up with bucket and thumb and dropped it.
farmerlund
North Dakota
Farmer/ excavator
That's what I was going to do also. now I just use a big piece of concrete, but sometimes its hard to get the first big one broke off. Chaining it to the bucket looks interesting and dangerous.
SpaceDog67
OHIO
never thought about using it that way. Well, I never actually:rolleyes: used one as well
Perth, Australia
Marketing Manager
I'd think that you could use a hydraulic hammer, hydraulic shear or a demolition grapple/shear on your excavator to accomplish what you want done provided you have a sufficient machine.
Steven Rogers
Washington state
I have a 1000lb ball for sale
TDF
Seward, Nebraska
What's the opinion on pile driver drop hammers for wrecking balls? I just bought two trailer loads of stuff and included are 3 pile driver drop hammers. Not quite sure on weight yet but they sure put a squat in the trailer when we set them on there. Maybe 2 or 3k lbs for the bigger one. I wanted the dragline bucket, clam, and hook block but the guy wouldn't split up the package so I ended up with a bunch of pile driving pieces.
TDF
old-iron-habit
Moose Lake, MN
TDF
View attachment 202174 View attachment 202175
That 3,000 lb drop hammer in the top picture could work well. I could see that busting up some decent size concrete. The biggest issue would be the flat bottom would be detrimental to point loading the impact. Perhaps welding up a steel pointed attachment securing with cable or steel loops into the side hooks similar to the driving bonnet it would of had on when in use as a pile driver would really make it hammer. (Pun intended.)
matnicoe
US
In demolition, prefer the controlled way with the use of diamond core drill. But wrecking all is less expensive especially for general demolition.
dirty4fun
N. IL
I used a drop hammer on some concrete, if you can get it to fall perfectly straight it worked pretty good. Punched a rectangular hole through the basement floor. If it landed on an angle just a small hole, does seem to work as good as a round bottomed ball. The round ball did more damage, due to the shape and not having to land perfectly each time.
