biodiesel
To test the integrity of the cable you need to do a cranking voltage drop test.I am assumeing a 12 volt system,with your voltmeter set on low voltage 1 to 3 voltsDC you clamp the positive lead on the battery and the negative lead on the other end of that cable at the starter.Read the volt meter while trying to crank the starter motor.The spec is .1 volt per foot of cable.A 3 foot cable should be @ or less than.3 volts while cranking(or trying to crank).you should do this on all your heavy gauge battery cables.You can also test regular post type battery connections the same way(to verify the need to service your battery cable connections).To do this you would put the pos clamp on the cable clamp end and hold the neg end on the post in the center of the clamp being carefull not to touch the clamp as that would cause you to get no reading.You would be amazed how much voltage would use the less resistant voltmeter path around a dirty battery post.
