why does my jlg 450a main boom settles
Discussion in 'Forklifts/Telehandlers' started by donald thompson, Jun 9, 2020.
  1. donald thompson
    donald thompson Member
    Jun 8, 2020
    7
    iowa
    1 have a 1999 JLG 450A, #0300041500, dual fuel lift. the upper/main boom settles about 1.5 feet in 5 to 7 minutes. slower if the lift is shutoff and no one is in the basket, and a bit faster if the boom is extended all the way out.
  2. skata
    skata Senior Member
    May 10, 2007
    769
    midwest
    Does it settle and stop? Or go all the way down?
  3. donald thompson
    Jun 8, 2020
    7
    iowa
    it will go all the way down
  4. skata
    skata Senior Member
    May 10, 2007
    769
    midwest
    It's either worn seals inside the cylinder, or something wrong with the lock valve on the cylinder, that's the valve block mounted on cylinder that prevents the cylinder from moving in case of hose burst.
  5. Paul Council
    Paul Council Senior Member
    Oct 12, 2018
    380
    Somewhere
    Leaning towards the holding valve on the boom cylinder.
    mg2361 likes this.
  6. donald thompson
    Jun 8, 2020
    7
    iowa
    if my memory is right i think we replace the seals on that cylinder about a year ago and the seals on the holding valve. that does not mean i did it right
  7. donald thompson
    Jun 8, 2020
    7
    iowa
    more info maybe? when the lower/mid booms are lower, it bounces. if i press the boom retract switch it stops the bouncing, even if the boom is not extended. release the switch after 2-3 sec and everything works fine until i do it again.
  8. Txhayseed
    Txhayseed Well-Known Member
    Dec 23, 2019
    87
    Texas
    I would check the counter balance valves.
  9. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    1,482
    Professional Wrench Spinner
    Canuckistan
    2nd the counterbalance valves. Replaced many of those due to drift or leakage.
    Paul Council likes this.
  10. donald thompson
    Jun 8, 2020
    7
    iowa
    counterbalance valves, holding valve, lock valve, these are all the same valve right? in the block on the cylinder?
  11. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    2,294
    Oklahoma
    Correct. Different manufacturers call them different names but they are the same thing.
  12. donald thompson
    Jun 8, 2020
    7
    iowa
    thank you all. i guess i'll order a new valve and see if that fixes it
  13. donald thompson
    Jun 8, 2020
    7
    iowa
    replaced the holding valve and it appears to have worked. thanks to everyone
