Plaptown
Had the dozer a few years, not many hours on it yet and not alot of experience working on it but doing some maintenance now. Manual is very confusing; must've read these pages 4 times over.
1) the steering clutch oil - I see two plugs under the back of the machine (see photos) but my manual says there's only one for the steering clutch oil? Would I assume one drains the right steering clutch and one drains the left?? or is one something else?
2) Filling the steering clutch oil - my manual says there is a fill port for steering clutches above the right final drive fill port.... my machine has one on the left but not the right. I assume this port on the left side fills (both) steering clutches?
3) The transmission case, I'm assuming you need to remove the belly pan cover to get at the drain? (even though my manual says you don't)
