wheel loader L330 E engine cooling fan
abedsunna
Oman
hello
my volvo L330E engine cooling fan not working and hydrulic not reach to pipes of the fan
any help please where to check?
abedsunna
Oman
what you mean with reversible fan ? is it 2 way running you mean ?
honestly i dont know
abedsunna
Oman
this is some of errors
funwithfuel
Will county Illinois
Mechanic
You're going to want to check SE502 , that dictates MA202 to charge the brake accumulators. If all the oil is being thrown at the brake accumulators, there's none left for the fan.
For testing, curl your bucket back over relief, hold it for 10 seconds. That should satisfy brake charging. If the fan has not engaged, that's an indication that the sensor or fuse may have failed. I believe it is f22 that feeds the sensor. Check the sensor itself to verify power on one side of the connector. Please report findings.
abedsunna
Oman
hello
i check all fuses and all ok
kindly need more explain with drawing manual for se502 and ma202
also the location of the sensor
thank you
abedsunna
Oman
hello
i change the hydrulic pump and change the sensor plug and it works
it looks the pump defected as i can hear strange sound inside it
