Kidney-looping aka dialysis. On the rear axle the suction side of a pump and a fine filter is connected to the diff drain plug. The return line is connected to the fill/level plug of one of the final drives. When your machine is on a 500-hour PM you hook up the dialysis equipment and leave it pumping during the whole time the PM is going on. Usuaully it gets used in conjunction with a particle counter so that you can measure the cleanliness of the oil before and after the process. The process can also be used in wheel loader axles, hydraulic systems, transmissions, everything except engines basically.
Here is an example although I'll say now I have never used this particular brand of cart, it's just what Google turned up.
http://www.normanfilters.com/filtra...idsubmission&gclid=CMGY07-PprACFUOo4AodISNTYQ
Be careful with oil analysis in oil-filled hubs. The oil gets changed so often (every 500 hours) that it can be extremely difficult to pick up trends caused by bearings wearing. I'll be honest and say that on front wheels I have found that if the bearings are correctly adjusted from the get-go they
usually don't give much trouble.
Using dialysis we run the oil in our truck rear axles (FDAO SAE 60, nobody in their right mind uses 50 any more) for 10,000 hours between changes. So basically we only have one oil change between new components and pulling them out at end of life.
Can't offer any ideas on grease-filled hubs to be honest. I have never worked on anything that big that didn't use oil as a lubricant in the front wheels.
