Whats this? Windrow Eliminator?
Silveroddo
Northern MN
Cruising the old interweb I came across this on an old champion on machinery trader. It looks to be mounted to a rear lift group and slides hydraulically side to side. I'm thinking its some kind of windrow eliminator/packer? Doing forestry work where you're dealing will grass and sod I've dreamt of something like this, never seen anything built for the purpose though. Anyone seen or used something like this?1.jpg
I saw that same ad and wondered what that wheel was for too. Champion made a windrow eliminator but it was completely different. I think there's pics. in brochures online. I thought maybe that wheel could be used for packing small windrows that come off the blade like when doing the final pass on gravel roads. Left loose might cause a vehicle to get squirlly if it hit it right.
Around here the county dumps rock on the pavement and then blades it into the shoulder. That would work perfect for rolling the shoulder while keeping the grader tires on the pavement.
cuttin edge
NB Canada
Finish grader operator
On the wrong side. Might be able to flip it around to the other side though.
cuttin edge
NB Canada
If your operators manual is still in your 730, there is a windrow eliminator in the attachments section. That might be where you saw it. This one is made by Craig. Looks a bit delicate. https://www.craigattachments.com/products/grader/windrow/series-ii-windrow-eliminator/
It might have been in the operators manual I saw it. Definately more than just a wheel and tire.
It had controls for some kind of sweeper in the cab. It looks the contraption on the back is made by Ateco.
cuttin edge
NB Canada
The broom most likely hooks to the rear. The interior is almost identical to my old 730. The circle looks to be in really good shape. The teeth are hardly worn at all.
