I'm ignorant in such things... What in the world are you guys talking about? A machine won't turn off and increases in RPM until some of them explode? I think I can safely assume that cutting power to the machine not working is a cause but I don't understand why that would happen? I guess like a old-school crank car or tractor it is creating it's own power?
Diesel engine runaway. So normally diesel engine speed is controlled (and limited) to its normal operating range by the governor, which automatically controls the supply of fuel to the engine’s injectors. In a runaway situation the normal governor control is not in effect. Can be for a number of reasons, often a result of a governor or fuel system malfunction. Two stroke detroits were especially famous for it when the rack would stick or not be set correctly.
A diesel engine can also runaway if the engine oil becomes its fuel supply as well. Cutting the diesel fuel supply in that case may be very well not stop it
A rarer type of runaway is if another fuel source is inhaled by the engine. The Texas City refinery explosion is thought to have been caused by a runaway engine in a truck running on refinery gasses
The usual method of a stopping a runaway is to kill the air supply. A shutdown flapper or holding a metal plate over a turbo inlet, or even discharging a CO2 extinguisher are three popular methods. Removing the fuel supply is another method, such as closing a supply valve or beating a fuel filter off with a hammer
The good news about runaways is that in this day and age of electronically managed engines they are much rarer
