The trailer looks good what with the center rail flange just above the deck (likely a pierced I beam with the crossmembers in the pierced hole) and the wheel wells as low as practical, nice tail etc. Will you get one with the ramps to the front?or the step? The product shows the hydraulic is an option, do you know if it is from the truck or self unit? y trailer has hydraulic ramps (my back loves em), but I have wounded my hydraulic hose fittings by backing over brush, lucky I didnt dent a ram. The two ramps allow for offloading on contoured sites such as off shoulder etc. When loading/unloading, I like to crib the trailer to the grade and let the ramps' hydraulic float so the ramp and the ram is not trying to hold the back of the trailer up.
Was wondering if the narrower equipment is/are able to access the trailer if the gap between the ramps is a fixed dimension? Reason I ask is because my trailer has two hydraulic operated ramps with a ramp mount hinge point. Not able to slide the ramps closer together. Good for the dozer and the TLB, not so good for the ride on compactor nor the mini. Compactor wants to fall tween the ramps, need to add planks and joists to bridge the gap (works ok but is time and hassle). The mini, being smaller, has to be hauled with the pickup and a small flatbed trailer.
