What brands of elevating scrapers used a Hancock design bowl?
Questionable wizard
Ohio
I've been told the Terex S17E. That bowl sure looks similar to the Wabco. Maybe I'm wrong. But the stationary cutting edge, and the strike-off blade attached to the moving floor have similar designs. The large pipe across the top rear of the bowl, etc. Later designs have the laid up box fabrication of the bowl walls like the backside of the Cat six way blades.
Tying the lower front of the bowl walls together with a cutting edge would sure strengthen the walls at the lower front
Tones
Ubique
Michigan and Terex S11e used Hancock bowels. There may be more.
RZucker
Wherever I end up
Mechanic/welder
S-35 Terex used a Hancock bowl too. A lot of the parts (floor rollers and hangers, etc.) were interchangeable with Michigan 33 yd and early Wabco 333 machines.
Questionable wizard
Ohio
I think your right. The early ones used bowls supplied by Hancock. Latest ones such as the Terex S17E built from 2000-2004 my have been licensed by Clark/Michigan/Hancock but built in house as Clark ceased production in the mid '80s(unless Terex had a small contract for bowls from Clark). Haven't researched Clark's production history for 1980s on. The first John Deere 840 with the PTO driven elevator were supplied by Johnson. I believe as Cats needs consumed Johnson's production(and Cat buyout), Deere continued the design with in-house upgrades(just a guess).
Now I'll come back and say the John Deere bowls sure look a lot like they had Hancock influence.
RZucker
Wherever I end up
Mechanic/welder
I stand corrected on the John Deere. Contractor Magazine I posted the link was off a little
No problem. In the late 60's my grandfather ran a bunch of the JD 5010 scrapers, they definitely showed the Hancock influence.
I did see one of the early 840 scrapers and it was a crude looking thing that I first thought was some farmer creation. Looking back now that may have been one of the first All Hancock builds.
traxcavator
NC
Clarendon Manufacturing built the bowl for the S-17E.
http://www.clarendononline.com/news/2000/0831/story_1.htm
Questionable wizard
Ohio
Interesting. Couldn't have been very many bowls built. I would like to find the serial number breaks for each production year for those machines.
http://www.clarendononline.com/news/2003/1009/story_3.htm
but High Plains Journal shows their still in business. May 4 2016
CLARENDON MANUFACTURING Company, sales, parts and service. Hancock and Johnson. Manta shows they have annual revenue of $5-10M
traxcavator
NC
traxcavator
NC
I recall reading that now, local Contractor had a new 17E in 2000-2001. I haven't seen it for a few years. I really wanted to play with it, but at the time I was a competitor...
Same here, the dealer here at the time had one on rent to a contractor about an hour away from me, not sure what happen to it after that. I don’t understand why Terex didn’t offer the tractor with the ts-14 to give it more power, they also could have built a single engine open bowl to compete with the 611 Cat was producing at the time. It needed some type of suspension system to compete with Cat and Deere.
Questionable wizard
Ohio
Terex had so many owners over the years, I don't think the R&D department was able to maintain a lot of enthusiasm to stay ahead of the bean counters. Especially with a world recession. If they had sunk more money into their wire harnesses to be more reliable, and integrated a suspended front axle to the TS14 tractors, they would have had a he!! of a machine. It's my belief there is an opportunity for aftermarket wire harnesses with upgraded sensors/switches for a lot of the older machines. Doesn't mater if we're talking about Terex or Wabco. I despise the European Cannon connectors Terex used. Wires are too thin, connector bodies are fragile and let moisture/dirt in. Deutch is much better. Pair new harnesses with Cat or Deere sensors and switches, machine uptime would improve.
RZucker
Wherever I end up
Mechanic/welder
I wonder if parts availability had anything to do with them disappearing? Suspension wouldn't be a deal killer for me. That 222F I posted above could outrun any 615 or 623 I ever ran against. But I was a tough guy then. :D
traxcavator
NC
Suspension wasn’t a deal killer for me either but I think most people wanted it. I’ve never operated a Wabco, TS-14s didn’t ride great and I assume the S-17 was a similar ride, but I really like the TS-18s and they rode much better than 14s in my opinion. Terex also didn’t do them selves any favors with the seats they started putting in those machines. I ran some TS-14Ds, Fs, Gs with the factory seats and they were not made for a scraper. Did you ever have any experience with S-23Es? I always wanted to try one but never had the opportunity.
Questionable wizard
Ohio
I've never run one. Would like to. Cherry S17E for sale in Decatur, IL. Only 1200 hours. Stored inside.
There are a lot of knick knack items they could have upgraded to make the whole package better. A swivel seat with an excavator joystick attached to the armrest similar to how the JD 8000 tractors are made would be better. Active seat suspension like the JD8X30 series tractors and newer would be best. Fuel gauges, cameras, GPS integration, etc. I believe since Terex from 1990 on wasn't a market leader, R&D and machine upgrades were kept on a choking budget. Also boiled down to local dealer support. Yes parts availability was an issue. As was CATs ability to send sales and service support reps around checking for customer relationship/equipment issues(i.e. iron out problems before they become serious issues) cast a large shadow over the minor brands. We've had enormous problems with CAT equipment, but the service rep stops by every 2-3 weeks, and they support the equipment. Back on topic, I've read all 51 pages of Wabco threads. Read over and over how the Hancock bowls load easier and faster. I'm an efficiency fanatic, just connecting the dots.
