NH575E
Yeah I got away with mig welding one of my stabilizer lines but the crack on it was right at the face seal flange. That's been holding 4 or 5 years. Even though I removed and flushed out this line there is no way to get all the oil contamination out so I figured brazing the surface would be easier than O/A welding and trying to penetrate the metal. I put a fairly thick layer of brass on and let it cool nice and slow.
I called all the local hydraulic shops and none were building hard lines.
If it breaks again the next step will be ordering a piece of tube, face seal flanges, and a bender to try and duplicate a new one. I could buy all that for about half the cost of the unobtainable line and have the bender left over.
Or I could replace it with a hose but that would make for less flow because it would need to be half the inside diameter to fit in the confined area at the base of the boom. May not be a bad thing to slow down the flow.
Some of the hard line anchor straps were missing on my machine when I got it. A couple of lines were gouged up from unsecured movement. The rivet nuts to hold the straps were missing and the only place I found them was a China dealer on eBay. The holes in the boom are 11mm hex shape and the rivet nuts are 8mm with a 11mm hex base. It took several weeks to get them from China. At least they are easy to set without a tool. The hex base holds them so all it takes is an 8mm bolt and flat washer to secure them.
One of the crowd cylinder lines cracked on the outside. The line is listed at $550 and showing backorder. I Mig welded the crack and it sealed good enough for cylinder travel but as soon as I applied digging pressure it leaked again. The damage was less obvious after I cleaned it up so put a layer of brass over the whole section with a flux coated brazing rod. After brazing it didn’t leak and stayed dry even after digging and tugging on a stump some. I think the leak is fixed for now. BUT the rivet nut for the strap holding the line near the pivot popped out. I don’t think I put enough tightness on it when I set it so I have to replace that again tomorrow. I may loosen them all and tighten all the replaced rivet nuts in the boom a little batter if that one will tighten all the way down without breaking..
Every time I removed the line strap anchor bolts another one of the factory rivet nuts would break off and fall in the boom. I would have to chisel the top crimped part out and set a new one. If you have a New Holland you probably want to source some of these to have handy. I don’t know how common they would be with any other brand?
Edit: Found some of these on Amazon.
https://www.amazon.com/uxcell-Bronze-Carbon-Hexagonal-Nutserts/dp/B01MS63NZ7/ref=sr_1_3?crid=2ROKGQA8KMYJA&keywords=8mm+hex+rivet+nut&qid=1656384423&sprefix=8mm+hex+rivet+nut,aps,260&sr=8-3
Thought I would follow up on this old thread. My brazing job held well enough to get some work done but had a fine crack that would spray some oil mist under heavy load. That started to worsen last week so I started shopping around again on Monday. I found both a local shop that would build the line and DOH!, a salvage yard that had a good used one 40 miles away.
The shop said they would build it for $200 or less and the salvage yard wanted a $110 for a used one. NH wants almost $600 for a new one. I went with the used line and no more spraying oil.
Both machines at the salvage yard were burned units and both lines had some rust but the one I bought was minimal. I sanded it all down and painted it with cold galvanized paint.
I had bought a loader frame for my JD years ago from the same yard but for some reason didn't think to call them about backhoe parts. They have a surprising number of burned tractors. The tractor I bought my loader frame off of was burnt. The parts puller guy said machine fires were a common result of mouse and rat damage.
