what are the hardest attachments on excavator
thorns
canada
looking at 270 excavator that was used primarily for residential demolition, as such it has had a jack hammer or pulverizer on it and I was not sure how hard that was on the boom, stick, and pins.
Also what would you say are the hardest attachments on an excavator?
3rdGenDslWrench
MD
Heavy Equipment Field Mechanic/ Truck Mechanic/Aut
the one thing I found to be the biggest pain in the *$$ is a stump splitter. We bought one for a 235 the first time we put it on was at the shop on concrete. Being that it was tall and narrow we ended up putting 2 dozers up against each side to hold her upright till we get the stick pin in. Eventually we built a stand that helped out transporting it and putting it on and off the machine.
Other than that, putting on any kind of attachment on anything larger than a 345 can be a little trialsome.
When they swap Diggers shovel and broom for a key to the Yanmar mini, whoa nelly look out!:eek:
GCC
Ontario, Canada
Excavation
I would have to second using the bucket as a hammer one of my operators did this just after brand new 100MM pins were put in the buck and after a weak of him smashing it against rock to try and dig a basement I was not present when this was happening the stick to bucket pin was pretty beat up and had to put all new teeth on and weld a new peace into the corner of the bucket as he got it under the edge of a slab and snapped the tooth and plate conneted to it off. Needless to say I garnessed his wages till the pin and bucket repairs were paid for and he's been the best operator I've known after having to pay for repairs and no its not legal for me to take his pay but I told him if he wanted a job still he was going to be paying for his stupidity like I own a hammer duh what's it for.
DGODGR
S/W CO
I always thought that the hammers were the hardest on the machine. That was up until I was invited to the Cat proving grounds, in Peoria, IL, to test out the prototype "D" model backhoes. I posed the same question to the man in charge of backhoe development (the head engineer for backhoes at Cat). His answer suprised me. He said that compaction wheels are the worst. He went on to explain that the hammer is really not that hard on the machine (unless the oil return line is not big enough). He went on to say that they found the wheel is worst because most operators will extend and retract, the dipper and boom, to the full extent of the travel of the respective cylinders. The momentum, of the boom and stick, in conjunction with the lack of resistance that the wheel affords (to the extension and contraction) allows great stresses to the cylinder when the piston bottoms out at the cylinder base or, especially, at the head gland. That's what he said anyway. He has the credentials so I figured he's right. I would think that it would be the same for excavators too since the work in such a similar way.
GCC
Ontario, Canada
Excavation
I dont know I would think a hammer would be harder due to the extensive pounding. Also they work for cat and might figure if they tell you a hammer is very hard on a machine then you might reframe from putting one on the machine which mean less sales which is no good to them. cat also claims best GPH yet my 1995 hitachi 300 gets better GPH then new cat 320 I rented lol. Cat employee's are the to tell you what you wanna here right as with any other brand.
jmoreland
Indiana
I also was told by a CAT dealer that the compaction wheel is the hardest attachment for an excavator.
87silvert
CT
I have a sk210lc with a 5000lb Indeco hammer on it. It sure looks brutal when you are pounding away and the dipper cylinder is bouncing up and down, but the machine has 1900 hrs, half with the hammer on with no problems at all. No rattles, squeaks, leaks or shakes, so I guess it is not as brutal as it looks.
I have to agree with the operator being the most damaging attachment at all.
The other thing, how much hammer work could be involved in residential demolition, most houses just about fall apart just touching them with an excavator, including the foundations.:cool2
WV earth mover
WV
this compaction wheel thing is starting to make me nervous mine just came today for a sk 160 thought it would be handy for slope work on damns and repair work for ponds to need the clay on 2 to 1 slope rather than just tracking alone i dont think hammers are as hard as people say when used right i recently looked at an sk 200 with 12400 hrs on it that belongs to a friend of mine who is selling it he says it has less than 2000hrs with a bucket and the rest a 4500pd hammer original pump lasted about 8500hrs still origanal boss pin and bushing although pretty sloppy now almost seemed like the hammer was easier than a bucket
