The less 32 nd's of tread depth the more likely a failure. The higher the ambient temp the road surface temp
climbs drastically. A drive tire with 19 32nd's tread depth inflated cold to 100 psi in 100* temps will run at
115 psi. A tire with 7 32nd's will be at 125 plus psi. Too much contact surface and way less air flow through
the tread. Recap tires especially-from years of experience I only inflate to a max 93 psi cold and a recap at that
psi has about a 80% less chance of exploding. That 8 psi difference on the top end of the scale makes a
huge difference.
huge difference.
