joedirtyshirt
Is there a spec. or Go-no-Go for small track skid loaders I've been thru the book and have come u short of an answer.
GTC01613 2013 299DIs there a spec. or Go-no-Go for small track skid loaders I've been thru the book and have come u short of an answer.
The instructions are also suitable for this machine.GTC01613 2013 299D
THANKS MUCH, New question for you since you seem to have access to info my Dealer can't find or get, in the wear guide (dealer never heard of) it mentions Kit for rear frame & front frame gap would you have any idea's on Cat kit , as of this morning Cat system is down for a week, according to my dealer, and the shim kit for the torsion axle end play, this is my oldest machine and tracks are starting to rub boom GTC01613 2013 299DThe instructions are also suitable for this machine.
All your dealer has to do is put a question into the Cat DSN system mentioning the document reference (M0073906) and quoting the text on Page 12 where it mentions..... "Shim strips are available as a permanent, welded solution to maintain a proper clearance between the two frames. Consult your dealer for this kitted solution".it mentions Kit for rear frame & front frame gap would you have any idea's on Cat kit ,
