I have decided a mud pump is not the way to go. I ran into a fellow that learned how to drills his own wells for his farm. He learned the hard way and in the process had 4 different bores collapse every time he attempted to use a mud pump each time spending more money to get more pressure. He used 2 different water swivels , one pro-made and a custom home made one and 3 different types of pumps including a top of the line 3" pump. No rock mostly sand and hard clays. According to him, it was too hard to get the cuttings out of the bore once you went below 35 to 40' deep. The sand would just want to sit back down on the auger and the boring would slow down to a snails pace.
He found out that an air pump is the way to go. Using a wheel barrow air compressor and a 1.5" pvc pipe along with an airline he was able to create a pump that would reach close to 90 gpm suction from 100' down. It will clean the sand and clay out just as fast as you cut the bore. Using a basic home made platform with a hydraulic motor from a lull he spins a short auger bit using the rigid metal pipe. Using a short 9' auger type bit and 3" ridged metal electrical pipe from home depot sold in 10' pieces. He uses this type pipe because the fittings are well machined and the pipe is very straight right from the big box store. After doing several small wells, he was able to increase to a large well with the goal being to run a pivot. Using a 24" top casing to a lower 18" screen getting 700 gallons a minute with a 30 horse electric motor. That is a $35,000.00 well.
Keeping the bore full of water from a gravity top feed is the key to keeping the bore open. The air pump will preform similar to an super expensive professional mud pump on a drill rig. The holding pond for the water to keep the bore full is quite large at 20' x 20" x 2' deep with an earth dam in the middle similar to a gold rush holding pond to allow the silt to settle out.
No special mud or pumps required. No pump is even used. The PVC pipe is duct taped together and increases in length as the auger goes down. It takes 3 people to do the job. One to hold the pvc just above the drill stem, one to keep up with the water and one to run the drill. Water from the holding pond is gravity feed to the bore hole with a 6" pipe.
Of course I figured this out after I bought my benonite, and water swivel bearings about $200.00 down the hole....
