CascadeScaper
- Joined
- Feb 27, 2005
- Messages
- 1,162
- Location
- Lynnwood, WA
- Occupation
- 2nd year Operating Engineer Apprentice
Anybody used one? A large contractor out here uses one even though they have like 5 or 6 4,000 gallon water trucks. They use it on their smaller jobs and tow it behind a 1 ton truck. This one is a double axle frame maybe 12 feet long with about a 300-400 gallon poly tank. I haven't gotten a good look at the trailer itself, it might have a pump, but you could set one up to gravity feed by having a hose hookup on each end of the tank if you were working on a slope. Getting water to a site isn't usually a big deal out here, but I got to thinking about it today on the machine. I actually thought about building one, maybe acquiring some sort of tank and chaining it my flatbed and using it as needed. Three or four hundred gallons doesn't last long, but it doesn't take long to fill either. Wouldn't be able to use it for bulk watering like roads or anything like that, but just enough water to backfill utility trenches in remote areas. Ideas?
